Ga door naar hoofdinhoud
Trek 820 Light Mount Replacement
Wat je nodig hebt
  1. Trek 820 Light Mount Replacement, Light Mount: stap 1, afbeelding 1 van 2 Trek 820 Light Mount Replacement, Light Mount: stap 1, afbeelding 2 van 2
    • Clean the area where the light mount will be installed with a soft cloth.
    • Placing the light mount close to the center stem.
  2. Trek 820 Light Mount Replacement: stap 2, afbeelding 1 van 1
    • Remove the strap from the light mount fitting.
    • Stretch the strap clockwise around the handlebars.
  3. Trek 820 Light Mount Replacement: stap 3, afbeelding 1 van 1
    • Slide the strap through the slot and fasten to a snug, but moveable fit.
    • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
  4. Trek 820 Light Mount Replacement: stap 4, afbeelding 1 van 1
    • Pull the strap tightly through the clasps at the bottom of the mount.
  5. Trek 820 Light Mount Replacement: stap 5, afbeelding 1 van 2 Trek 820 Light Mount Replacement: stap 5, afbeelding 2 van 2
    • Place the fastening screw in the rear screw port on the light mount.
    • Twist the screw clockwise using your hands until fully fastened.
Conclusie
Now you have a light mount ready for safer night rides on your Trek bicycle!
Kaveh Karimiyanha
813 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-1, Propen Fall 2012 Lid van Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 866
