Inleiding
This guide specifically demonstrates how to remove the tire from the front wheel of your bike. The process is similar for both the front and rear wheels. If you want to replace your rear tire, first just look at the guide showing how to remove the rear wheel then the sequential steps are the same.
Wat je nodig hebt
Stand facing your bike and locate the brake calipers.
To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
To deflate the tire, remove the cap and attach the pump head to the valve. You should then hear air flowing out from the tire.
