Ga door naar hoofdinhoud
Trek 4300 Bicycle Tire Replacement
Wat je nodig hebt
  1. Trek 4300 Bicycle Tire Replacement, Front Wheel: stap 1, afbeelding 1 van 2 Trek 4300 Bicycle Tire Replacement, Front Wheel: stap 1, afbeelding 2 van 2
    • Stand facing your bike and locate the brake calipers.
    • To lessen the tension on the brake wire, place one hand on each caliper and push them closer together.
  2. Trek 4300 Bicycle Tire Replacement: stap 2, afbeelding 1 van 2 Trek 4300 Bicycle Tire Replacement: stap 2, afbeelding 2 van 2
    • Unhook the brake wire in the metal tube from the brake wire holder on the brake caliper in your left hand.
  3. Trek 4300 Bicycle Tire Replacement: stap 3, afbeelding 1 van 1
    • Find the quick release lever located on the bikes fork to loosen the wheel from the frame.
    • Lift the lever from lock position 180 degrees until the open sign on the lever faces outward. Twist the lever while holding the pin on the opposite side of the wheel.
    • The quick release lever does not need to be completely removed.
    • Note which side of the bike the quick release lever is on for proper reassembly.
  4. Trek 4300 Bicycle Tire Replacement: stap 4, afbeelding 1 van 2 Trek 4300 Bicycle Tire Replacement: stap 4, afbeelding 2 van 2
    • Pull the frame of the bike upwards to separate the front wheel.
  5. Trek 4300 Bicycle Tire Replacement, Inner Tube: stap 5, afbeelding 1 van 1
    • To deflate the tire, remove the cap and attach the pump head to the valve. You should then hear air flowing out from the tire.
  6. Trek 4300 Bicycle Tire Replacement: stap 6, afbeelding 1 van 1
    • Push the valve upward through the hole in the rim.
  7. Trek 4300 Bicycle Tire Replacement: stap 7, afbeelding 1 van 2 Trek 4300 Bicycle Tire Replacement: stap 7, afbeelding 2 van 2
    • Pull the tire away from the rim until you can insert your fingers under the tire coping to remove it from inside the rim.
    • Slide your fingers (still under the tire coping) around the circumference of the tire until you completely remove the tire from the rim.
    • It is easier to start removing the tire from the rim around the location of the valve.
  8. Trek 4300 Bicycle Tire Replacement: stap 8, afbeelding 1 van 1
    • Holding the valve, pull the tube out from the inside of the tire.
  9. Trek 4300 Bicycle Tire Replacement, Tire: stap 9, afbeelding 1 van 1
    • Examine the inside of the tire to check for holes or tears before replacing.
Conclusie
Erin Ferguson
447 Reputatie
4 handleidingen geschreven
Clemson, Team 3-2, Benson Fall 2014 Lid van Clemson, Team 3-2, Benson Fall 2014
CLEM-BENSON-F14S3G2
4 Leden
8 handleidingen geschreven
Één opmerking
Really very helpful. Clear presentation. Thanks
CharlesGoodall - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 2,733
