Ga door naar hoofdinhoud
Traxxas Summit Steering Assembly Servo Replacement
Wat je nodig hebt
  1. Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: stap 1, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: stap 1, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement, Steering Assembly Servo Replacement: stap 1, afbeelding 3 van 3
    • Remove each of the four pins that hold the shell by pulling them from the posts.
  2. Traxxas Summit Steering Assembly Servo Replacement: stap 2, afbeelding 1 van 2 Traxxas Summit Steering Assembly Servo Replacement: stap 2, afbeelding 2 van 2
    • Remove the shell by grabbing it with both hands and lifting upwards.
  3. Traxxas Summit Steering Assembly Servo Replacement: stap 3, afbeelding 1 van 2 Traxxas Summit Steering Assembly Servo Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the battery from the device by pulling the black plastic connector apart.
  4. Traxxas Summit Steering Assembly Servo Replacement: stap 4, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 4, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the four power cables that connect the motor to the electronic speed control.
    • Grab the connectors by their rubber covered metal ends rather than the wire if possible.
  5. Traxxas Summit Steering Assembly Servo Replacement: stap 5, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 5, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 5, afbeelding 3 van 3
    • Unscrew the single 15.5mm long retaining bolt from the motor with the 3mm hex key.
    • Remove the motor by wiggling back and forth while pulling it to the right and up.
  6. Traxxas Summit Steering Assembly Servo Replacement: stap 6, afbeelding 1 van 2 Traxxas Summit Steering Assembly Servo Replacement: stap 6, afbeelding 2 van 2
    • Flip the car on its back to provide access to the steering assembly.
  7. Traxxas Summit Steering Assembly Servo Replacement: stap 7, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 7, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the servo arm from the steering assembly by removing the 16.3mm long screw with a 2mm hex key.
    • Pull the connecting linkage out of the steering horn.
  8. Traxxas Summit Steering Assembly Servo Replacement: stap 8, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 8, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 8, afbeelding 3 van 3
    • Flip the car back upright.
    • Remove the two 7mm long screws retaining the largest wiring cover with the 2mm hex key.
    • Take the largest wiring cover off.
    • Remove the two 7mm long screws retaining the smaller wiring cover with the 2mm hex key.
  9. Traxxas Summit Steering Assembly Servo Replacement: stap 9, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 9, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 9, afbeelding 3 van 3
    • Remove the second wiring cover.
    • Pull the servo connecter out of the receiver.
    • Work the cable out of the receiver box.
  10. Traxxas Summit Steering Assembly Servo Replacement: stap 10, afbeelding 1 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 10, afbeelding 2 van 3 Traxxas Summit Steering Assembly Servo Replacement: stap 10, afbeelding 3 van 3
    • Remove the four 9mm long screws that retain the faulty steering servo with the 2.5mm hex key.
    • Pull the servo out.
    • Turning the servo horn by hand may be necessary to fit it through the hole.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 2,321
