Inleiding
This guide is for the Traxx LED Metallic Selfie Ring. Selfie rings are used as additional lighting for taking photos with a phone. This guide will walk you through the steps of removing the old batteries and replacing new batteries in your selfie ring. It will show you which end of the battery is positive and which end is negative and which way to insert these into the battery slots.
Wat je nodig hebt
Bijna klaar!
To reassemble your device, follow the instructions in reverse order.
Conclusie
