Inleiding
This guide will show you how to replace the speakers in your Toshiba Thrive.
Wat je nodig hebt
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a PH0 phillips head screwdriver to remove the 12 screws holding on the back cover
All of these screws are identical so don't worry about getting them mixed up.
Use the plastic opening tool to open the latch holding the last wire to the back of the device.
Één andere persoon heeft deze handleiding voltooid.
