Inleiding
Is your speaker volume too low or not there at all? If so you’ll need to replace your faulty speakers with new ones. This guide will show you the steps you need to know.
Wat je nodig hebt
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
