Ga door naar hoofdinhoud
Toshiba Tecra Z50-A Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Tecra Z50-A Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Motherboard Replacement, CPU Fan and Heat Sink: stap 8, afbeelding 1 van 1
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
  13. Toshiba Tecra Z50-A Motherboard Replacement, Motherboard: stap 13, afbeelding 1 van 1
    • Remove the two 5 mm screws using a Phillips #0 screwdriver.
  14. Toshiba Tecra Z50-A Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the three 5 mm screws using a Phillips #0 screwdriver.
  15. Toshiba Tecra Z50-A Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Lift up on plastic covering over the Wi-Fi card.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
  16. Toshiba Tecra Z50-A Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Unplug the bundled red and black cable from its connector on the motherboard.
  17. Toshiba Tecra Z50-A Motherboard Replacement: stap 17, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Lift up on the black retaining flap using a pair of tweezers.
  18. Toshiba Tecra Z50-A Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Push the tab on the right toward the top of the laptop.
  19. Toshiba Tecra Z50-A Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Push the tab on the left toward the top of the laptop.
  20. Toshiba Tecra Z50-A Motherboard Replacement: stap 20, afbeelding 1 van 1
  21. Toshiba Tecra Z50-A Motherboard Replacement: stap 21, afbeelding 1 van 1
  22. Toshiba Tecra Z50-A Motherboard Replacement: stap 22, afbeelding 1 van 1
    • Lift up on the charging port with tweezers.
  23. Toshiba Tecra Z50-A Motherboard Replacement: stap 23, afbeelding 1 van 1
    • Lift up on the plastic tab.
  24. Toshiba Tecra Z50-A Motherboard Replacement: stap 24, afbeelding 1 van 1
    • Pull plug towards the bottom of the laptop.
  25. Toshiba Tecra Z50-A Motherboard Replacement: stap 25, afbeelding 1 van 1
    • Grab the middle of the motherboard with your hands and lift up to remove it from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luis Juen Baez
585 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 829
