Inleiding
If you’re experiencing a hardware failure or just want an upgrade to your device’s performance, this guide will walk you through the steps of replacing your hard drive.
Wat je nodig hebt
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
