Ga door naar hoofdinhoud
Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement
Wat je nodig hebt
  1. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, Battery: stap 3, afbeelding 1 van 1
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 6, afbeelding 1 van 1
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 7, afbeelding 1 van 1
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement, CPU Fan and Heat Sink: stap 8, afbeelding 1 van 1
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 11, afbeelding 1 van 1
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A CPU Fan and Heat Sink Replacement: stap 12, afbeelding 1 van 1
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luis Juen Baez
585 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 2-4, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G4
3 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 408
