Ga door naar hoofdinhoud
Toshiba Tecra M2 CPU Replacement
Wat je nodig hebt
  1. Toshiba Tecra M2 CPU Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop upside down so the back compartment is facing up.
    • Place left thumb on the battery lock tab.
    • Place right thumb on the battery release latch.
  2. Toshiba Tecra M2 CPU Replacement: stap 2, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 2, afbeelding 2 van 2
    • Slide both tabs outward at the same time to release battery pack.
  3. Toshiba Tecra M2 CPU Replacement: stap 3, afbeelding 1 van 1
    • Pull out the battery after it has popped out and set aside.
    • The battery and the battery cover are in one piece
  4. Toshiba Tecra M2 CPU Replacement, CPU: stap 4, afbeelding 1 van 1
    • Use a #00 phillips head screwdriver to remove the 8mm screw for the keyboard strip located under the battery.
  5. Toshiba Tecra M2 CPU Replacement: stap 5, afbeelding 1 van 1
    • Turn the device over and open it up to the display.
    • Gently lift a corner of the keyboard strip until it pops out of its position.
  6. Toshiba Tecra M2 CPU Replacement: stap 6, afbeelding 1 van 1
    • Using a #00 phillips head screwdriver, remove the two 4mm screws found underneath the keyboard strip.
  7. Toshiba Tecra M2 CPU Replacement: stap 7, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 7, afbeelding 2 van 2
    • Pop the keyboard up gently and rest on top of the touch pad
    • The keyboard is attached underneath by a thin film. Do not rip the keyboard off. Gently lay it down without ripping the film.
  8. Toshiba Tecra M2 CPU Replacement: stap 8, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 8, afbeelding 2 van 2
    • Using a #00 phillips head screwdriver, remove the 6mm screw holding the metal plate down.
  9. Toshiba Tecra M2 CPU Replacement: stap 9, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 9, afbeelding 2 van 2
    • Gently remove the keyboard connector film from the motherboard with fingers by lifting upwards.
    • Set aside the keyboard.
  10. Toshiba Tecra M2 CPU Replacement: stap 10, afbeelding 1 van 1
    • Using a #00 phillips head screwdriver, remove the three 13mm screws holding down the touch pad's frame from underneath the keyboard.
  11. Toshiba Tecra M2 CPU Replacement: stap 11, afbeelding 1 van 3 Toshiba Tecra M2 CPU Replacement: stap 11, afbeelding 2 van 3 Toshiba Tecra M2 CPU Replacement: stap 11, afbeelding 3 van 3
    • Flip laptop back upside down.
    • Remove the 5mm lock screw, using a #00 phillips head screwdriver.
    • Slide bay latch toward the battery compartment.
    • Remove CD-RW/DVD-ROM drive.
  12. Toshiba Tecra M2 CPU Replacement: stap 12, afbeelding 1 van 1
    • Remove the 4.5mm screw located under the CD-RW/DVD-ROM drive compartment, using a #00 phillips head screwdriver.
  13. Toshiba Tecra M2 CPU Replacement: stap 13, afbeelding 1 van 1
    • Remove the three 17mm screws found on the backside of the laptop using a #00 phillips head screwdriver.
    • Remove the ten 8mm screws using a #00 phillips head screwdriver.
  14. Toshiba Tecra M2 CPU Replacement: stap 14, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 14, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Flip the laptop back over and unplug the touch pad's power cord from the motherboard gently using a pair of tweezers.
  15. Toshiba Tecra M2 CPU Replacement: stap 15, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 15, afbeelding 2 van 2
    • Lift off the plastic cover and set it aside.
  16. Toshiba Tecra M2 CPU Replacement: stap 16, afbeelding 1 van 2 Toshiba Tecra M2 CPU Replacement: stap 16, afbeelding 2 van 2
    • Using a #00 phillips head screwdriver, unscrew the three 5mm screws holding down the heat sink securing bracket.
    • Lift off the securing bracket and set aside.
  17. Toshiba Tecra M2 CPU Replacement: stap 17, afbeelding 1 van 1
    • Wiggle the heat sink until it lifts off the top of your CPU. There is thermal paste underneath and it may stick.
  18. Toshiba Tecra M2 CPU Replacement: stap 18, afbeelding 1 van 3 Toshiba Tecra M2 CPU Replacement: stap 18, afbeelding 2 van 3 Toshiba Tecra M2 CPU Replacement: stap 18, afbeelding 3 van 3
    • Turn a flathead #3 screwdriver counter-clockwise to unlock the CPU socket.
    • Grab the CPU with your index finger and thumb and pull directly upwards.
    • Apply a new coat of thermal paste before reassembling.
    • Aanbrengen van koelpasta
Conclusie
Cindy Nguyen
386 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 1-6, Bruce Fall 2014 Lid van CSU Fullerton, Team 1-6, Bruce Fall 2014
CSUF-BRUCE-F14S1G6
3 Leden
9 handleidingen geschreven
1Gids Commentaar
"Step 4 - CPU" THAT IS NOT A 8MM SCREW! THERE IS NOW A HOLE IN MY COMPUTER!!
[deleted] - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,687
