Inleiding
If your Toshiba Tecra 8200 is running slowly or you are unable to save documents, your hard drive may need replacement.
Wat je nodig hebt
Locate the hard drive panel.
Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
Save the screw, as it will be needed for reassembly.
Remove the panel, exposing the hard drive.
Bijna klaar!
Eindstreep
