Ga door naar hoofdinhoud
Toshiba TECRA R940 Back Panel Replacement
Wat je nodig hebt
  1. Toshiba TECRA R940 Back Panel Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Back Panel Replacement: stap 2, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement: stap 2, afbeelding 2 van 2
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Back Panel Replacement, Back Panel: stap 3, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement, Back Panel: stap 3, afbeelding 2 van 2
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Back Panel Replacement: stap 4, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Back Panel Replacement: stap 5, afbeelding 1 van 1
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Back Panel Replacement: stap 6, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement: stap 6, afbeelding 2 van 2
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Back Panel Replacement: stap 7, afbeelding 1 van 2 Toshiba TECRA R940 Back Panel Replacement: stap 7, afbeelding 2 van 2
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 986
