Ga door naar hoofdinhoud
Toshiba TDP-XP2 Fuse Replacement
Wat je nodig hebt
  1. Toshiba TDP-XP2 Fuse Replacement, Fuse: stap 1, afbeelding 1 van 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: stap 1, afbeelding 2 van 3 Toshiba TDP-XP2 Fuse Replacement, Fuse: stap 1, afbeelding 3 van 3
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fuse Replacement: stap 2, afbeelding 1 van 2 Toshiba TDP-XP2 Fuse Replacement: stap 2, afbeelding 2 van 2
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fuse Replacement: stap 3, afbeelding 1 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 3, afbeelding 2 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 3, afbeelding 3 van 3
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fuse Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fuse Replacement: stap 5, afbeelding 1 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 5, afbeelding 2 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 5, afbeelding 3 van 3
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fuse Replacement: stap 6, afbeelding 1 van 2 Toshiba TDP-XP2 Fuse Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fuse Replacement: stap 7, afbeelding 1 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 7, afbeelding 2 van 3 Toshiba TDP-XP2 Fuse Replacement: stap 7, afbeelding 3 van 3
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fuse Replacement: stap 8, afbeelding 1 van 1
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fuse Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fuse Replacement: stap 10, afbeelding 1 van 2 Toshiba TDP-XP2 Fuse Replacement: stap 10, afbeelding 2 van 2
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fuse Replacement: stap 11, afbeelding 1 van 2 Toshiba TDP-XP2 Fuse Replacement: stap 11, afbeelding 2 van 2
    • Locate the fuse near where the power adapter was.
    • De-solder the fuse and replace with an equivalent fuse (Fuse leads to de-solder are marked in red).
Conclusie
Bryan Underwood
697 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 334
