Ga door naar hoofdinhoud
Inleiding
If you need to replace the RAM stick, follow this guide. The RAM stick can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic prying tool.
Onderdelen
  1. Remove the battery by sliding the tabs to the left.
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Grab the RAM stick by the protruding edge.
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
Conclusie
Danny Amado
799 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G3, Williams Fall 2018 Lid van Baylor, Team S1-G3, Williams Fall 2018
BU-WILLIAMS-F18S1G3
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 4
Altijd: 93
