Ga door naar hoofdinhoud
Toshiba Satellite e205 Wireless Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite e205 Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite e205 Wireless Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Wireless Card Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Wireless Card Replacement: stap 4, afbeelding 1 van 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Wireless Card Replacement, Bottom Cover: stap 5, afbeelding 1 van 1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Wireless Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Wireless Card Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite e205 Wireless Card Replacement: stap 8, afbeelding 2 van 2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Wireless Card Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite e205 Wireless Card Replacement: stap 9, afbeelding 2 van 2
    • Remove the two screews.
  10. Toshiba Satellite e205 Wireless Card Replacement: stap 10, afbeelding 1 van 1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Wireless Card Replacement: stap 11, afbeelding 1 van 1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Wireless Card Replacement: stap 12, afbeelding 1 van 1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: stap 13, afbeelding 1 van 2 Toshiba Satellite e205 Wireless Card Replacement, Wireless Card: stap 13, afbeelding 2 van 2
    • Locate the wireless card.
    • Remove the white antenna lead.
    • Remove the single screw.
    • Lift the card up from the edge with the screw, and pull out.
Conclusie
Tyler
4.920 Reputatie
16 handleidingen geschreven
TechForce Lid van TechForce
Business
2 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 343
