Ga door naar hoofdinhoud
Toshiba Satellite e205 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite e205 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
Conclusie
Tyler
4.968 Reputatie
16 handleidingen geschreven
TechForce Lid van TechForce
Business
2 Leden
25 handleidingen geschreven
2 opmerkingen
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - Antwoord
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 662
