Ga door naar hoofdinhoud
Toshiba Satellite c650d Fan Replacement
Wat je nodig hebt
  1. Toshiba Satellite c650d Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Fan Replacement: stap 2, afbeelding 1 van 1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Fan Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite c650d Fan Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Fan Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
    • Make sure you keep track of all the screws.
  5. Toshiba Satellite c650d Fan Replacement: stap 5, afbeelding 1 van 1
    • Flip the computer over.
    • Use a nylon spudger to lift the keyboard.
    • Go around the edge of the keyboard and lift until the keyboard separates from the back.
    • Only lift the keyboard a little at a time, otherwise you risk damaging the plastic.
  6. Toshiba Satellite c650d Fan Replacement: stap 6, afbeelding 1 van 1
    • Detach the ribbon cable that connects the keyboard to the motherboard.
  7. Toshiba Satellite c650d Fan Replacement, Fan: stap 7, afbeelding 1 van 1
    • Detach the cable connecting the fan to the motherboard.
  8. Toshiba Satellite c650d Fan Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite c650d Fan Replacement: stap 8, afbeelding 2 van 2
    • Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
  9. Toshiba Satellite c650d Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the fan by pulling it out slowly.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Brenna Callahan
868 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,409
