Inleiding
The RAM is the amount of data that can be accessed at the same time. By upgrading this, you will be able to multitask and run more programs without slowing down the computer. Before beginning this guide, make sure to have purchased the memory board you wish to install.
  1. Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side. Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  3. Locate and pull back the two mounting clips on either side of the memory chip.
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  4. Lift RAM circuit board to about a 45 degree angle and pull gently to the right. Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
Conclusie
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
Brandon Kirklen
269 Reputatie
8 handleidingen geschreven
Cal Poly, Team 7-8, Maness Winter 2013 Lid van Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Leden
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Aller tijden: 465
