Ga door naar hoofdinhoud
Toshiba Satellite U405D-S2902 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite U405D-S2902 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
Conclusie
Brandon Kirklen
311 Reputatie
8 handleidingen geschreven
Cal Poly, Team 7-8, Maness Winter 2013 Lid van Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 15
Altijd: 615
