Ga door naar hoofdinhoud
Inleiding
Sometimes the hard drive is corrupt, or you want to install a new one. This guide will show you how to take out a hard drive and replace.
  1. Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center. The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
    • The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
  2. After lifting the cover up carefully, slide it to the left to be removed.
    • After lifting the cover up carefully, slide it to the left to be removed.
  3. Place two fingers gently on the hard drive. Slide it back to the left. Lift the drive by the two corner tabs making sure not to touch the metel
    • Place two fingers gently on the hard drive.
    • Slide it back to the left.
    • Lift the drive by the two corner tabs making sure not to touch the metel
    • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
Conclusie
Brandon Kirklen
311 Reputatie
8 handleidingen geschreven
Cal Poly, Team 7-8, Maness Winter 2013 Lid van Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 427
