Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners. Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop. Carefully pull the top away from the back. Carefully pull the top away from the back.
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. Turn the laptop around. Remove the webcam/microphone data cable. Remove the webcam/microphone data cable.
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  6. Remove the lower lighting power supply. Remove the signal light power supply and data cable.
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  7. Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display. After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  8. Carefully remove the screen from the side brackets. Remove the LCD ribbon connector from the display.
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brandon Kirklen
290 Reputatie
8 handleidingen geschreven
Cal Poly, Team 7-8, Maness Winter 2013 Lid van Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 588
