Ga door naar hoofdinhoud
Toshiba Satellite U405D-S2902 Battery Replacement
  1. Toshiba Satellite U405D-S2902 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure that the laptop is off and unplugged.
    • Turn the laptop over.
    • Slide back the left lock, and you should hear a click when it is successfully locked back in.
  2. Toshiba Satellite U405D-S2902 Battery Replacement: stap 2, afbeelding 1 van 1
    • Rotate the laptop 180 degrees so that the battery is near you.
    • Hold back the spring slide and pull the battery out.
Conclusie
Brandon Kirklen
311 Reputatie
8 handleidingen geschreven
Cal Poly, Team 7-8, Maness Winter 2013 Lid van Cal Poly, Team 7-8, Maness Winter 2013
CPSU-MANESS-W13S7G8
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 10
Altijd: 516
