Inleiding
If your Toshiba Satellite S55t-C5225 is experiencing quality errors in the screen or visible damage then the screen might need to be replaced. This replacement guide should be followed if you are experiencing the problems mentioned above.
Wat je nodig hebt
Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
Pull the ribbon wire out from plastic clamp.
Disconnect LAN from the motherboard power wire. Pop up the white clamp that holds it in place, then pull the wire out.
Één andere persoon heeft deze handleiding voltooid.
