Ga door naar hoofdinhoud
Toshiba Satellite S55t-C5225 Screen Assembly Replacement
Wat je nodig hebt
  1. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: stap 4, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 5, afbeelding 2 van 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 6, afbeelding 2 van 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 8, afbeelding 2 van 2
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 9, afbeelding 2 van 2
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 10, afbeelding 2 van 2
    • Lift speakers up from their mounted position to remove.
  11. Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: stap 11, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement, Screen Assembly: stap 11, afbeelding 2 van 2
    • Disconnect LAN from the motherboard power wire. Pop up the white clamp that holds it in place, then pull the wire out.
  12. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 12, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the two cables connecting the screen assembly to the WIFI card.
  13. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 13, afbeelding 3 van 3
    • Disconnect all remaining cables that connect the screen assembly to the motherboard.
  14. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 14, afbeelding 1 van 1
  15. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 15, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 15, afbeelding 2 van 2
    • Remove the four 7.0 mm Phillips #0 screws on both ends of the laptop that attach the screen assembly to the laptop.
  16. Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 16, afbeelding 1 van 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 16, afbeelding 2 van 3 Toshiba Satellite S55t-C5225 Screen Assembly Replacement: stap 16, afbeelding 3 van 3
    • Slowly open laptop while the bottom is facing up. Begin to separate the bottom of laptop from the screen assembly brackets.
    • Remove the screen assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Javien Delgado
220 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 798
