Inleiding
If your Toshiba Satellite S55t-C5225 shuts down abruptly, performance is low, or fails to install new programs then the RAM most likely needs to be replaced. The following guide will walk the user through replacing the RAM in your Toshiba Satellite S55t-C5225.
Wat je nodig hebt
Press on the metals clips on the outside of the RAM to release it.
Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
3 andere personen hebben deze handleiding voltooid.
