Ga door naar hoofdinhoud
Toshiba Satellite S55t-C5225 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite S55t-C5225 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 RAM Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 RAM Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 RAM Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 RAM Replacement: stap 3, afbeelding 2 van 2
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: stap 4, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 RAM Replacement, Back Panel: stap 4, afbeelding 2 van 2
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 RAM Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 RAM Replacement: stap 5, afbeelding 2 van 2
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 RAM Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite S55t-C5225 RAM Replacement: stap 6, afbeelding 2 van 2
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 RAM Replacement, RAM: stap 7, afbeelding 1 van 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: stap 7, afbeelding 2 van 3 Toshiba Satellite S55t-C5225 RAM Replacement, RAM: stap 7, afbeelding 3 van 3
    • Press on the metals clips on the outside of the RAM to release it.
    • Gently pull out the first RAM stick. Repeat the process for the other RAM stick.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Javien Delgado
220 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G5, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G5
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 393
