Ga door naar hoofdinhoud
Toshiba Satellite S55t-A5389 Processor Replacement
Wat je nodig hebt
  1. Toshiba Satellite S55t-A5389 Processor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the fourteen 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Processor Replacement: stap 2, afbeelding 1 van 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  3. Toshiba Satellite S55t-A5389 Processor Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite S55t-A5389 Processor Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite S55t-A5389 Processor Replacement: stap 3, afbeelding 3 van 3
    • Remove the four 5mm Phillips #0 screws from the battery.
    • Unplug the battery from the motherboard.
    • Remove the battery from the laptop.
  4. Toshiba Satellite S55t-A5389 Processor Replacement, Processor Fan: stap 4, afbeelding 1 van 1
    • Remove the two 5mm Phillips #0 screws from the fan.
  5. Toshiba Satellite S55t-A5389 Processor Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the fan from the motherboard.
  6. Toshiba Satellite S55t-A5389 Processor Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 5mm Phillips #0 screws from the heat pipe.
    • Remove the fan and heat pipe from the laptop.
  7. Toshiba Satellite S55t-A5389 Processor Replacement, Processor: stap 7, afbeelding 1 van 1
    • Rotate the lock 90 degrees using a Torx T8 in order to remove the processor.
  8. Toshiba Satellite S55t-A5389 Processor Replacement: stap 8, afbeelding 1 van 1
    • Carefully lift up the processor.
    • When putting the new processor on, make sure that the little arrow on the processor matches with the arrow on the socket
Conclusie
William Mazanec
1.350 Reputatie
8 handleidingen geschreven
USF Tampa, Team S5-G6, Passmore Spring 2018 Lid van USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Leden
Één opmerking
Can i use i7 4940mx cpu on this laptop
Movies Star - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 643
