Ga door naar hoofdinhoud
Toshiba Satellite S55t-A5389 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite S55t-A5389 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite S55t-A5389 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
Conclusie
3 andere personen hebben deze handleiding voltooid.
William Mazanec
1.350 Reputatie
8 handleidingen geschreven
USF Tampa, Team S5-G6, Passmore Spring 2018 Lid van USF Tampa, Team S5-G6, Passmore Spring 2018
USFT-PASSMORE-S18S5G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 18
Altijd: 591
