Ga door naar hoofdinhoud
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
Wat je nodig hebt
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 2, afbeelding 3 van 3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 4, afbeelding 1 van 1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 5, afbeelding 1 van 1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: stap 6, afbeelding 1 van 1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 7, afbeelding 1 van 1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: stap 8, afbeelding 1 van 1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
George Gillespie
721 Reputatie
7 handleidingen geschreven
USF Tampa, Team 2-1, Blackwell Fall 2016 Lid van USF Tampa, Team 2-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G1
4 Leden
Één opmerking
George, do you know where the graphics chip is at on that motherboard?
Any Where - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 1,197
