Inleiding
The keyboard may need to be replaced when a key(s) does not work as intended. This is possibly the most difficult part to replace on this laptop as it requires the most parts to be removed. Please refer to the Keyboard Troubleshooting Guide to determine if your keyboard needs to be replaced.
Wat je nodig hebt
Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
Remove the three 4 mm Phillips #1 screws holding the motherboard in place.
Remove the twenty-seven 2 mm Phillips #0 screws that secure the keyboard retaining plate.
4 andere personen hebben deze handleiding voltooid.
