Inleiding
This guide details how to replace the hard drive of a Toshiba Satellite S50-B laptop. You will need a Phillips 0 screwdriver and a plastic opening tool for this replacement.
Wat je nodig hebt
Unscrew the two 6.5mm screws below the battery using a Phillips #0 Screwdriver.
Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
Use a plastic opening tool to remove bottom casing.
4 andere personen hebben deze handleiding voltooid.
