Ga door naar hoofdinhoud
Toshiba Satellite Radius P55W-B5220 Back Cover Replacement
Wat je nodig hebt
  1. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn off the laptop before starting.
    • Remove the two rubber feet closest to the hinge with a plastic opening tool.
  2. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the twelve M2x4mm PH0 Philips head screws.
  3. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Loosen the back cover with a plastic opening tool.
    • The least damaging way to pry the cover is to start from a corner and run the spudger along the edge.
    • Do not crack or bend the cover.
  4. Toshiba Satellite Radius P55W-B5220 Back Cover Replacement: stap 4, afbeelding 1 van 1
    • Carefully lift open the cover.
    • Remove the attached purple ribbon cable underneath the cover.
    • Do not rip the ribbon cable.
Conclusie
Devin Boski
478 Reputatie
3 handleidingen geschreven
Één opmerking
Can you show replace this model display, and please please, give de part number of the screen
Erick Ramon Garibay Valencia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,277
