Ga door naar hoofdinhoud
Toshiba Satellite P855-S5312 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: stap 2, afbeelding 2 van 3 Toshiba Satellite P855-S5312 Keyboard Replacement, Keyboard: stap 2, afbeelding 3 van 3
    • Using plastic spudger to pry up the edges of the keyboard and lift it towards the screen.
    • Unplug the ZIF connector ribbon using the plastic spudger by gently prying the edges of the plug.
    • Remove the keyboard from the device.
Conclusie
To reassemble your device, plug the ribbon into circuit board and snap the replacement keyboard in place.
Dalton
215 Reputatie
2 handleidingen geschreven
USF Tampa, Team S10-G2, Thompson Fall 2017 Lid van USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 1,207
