Inleiding
Guide is to replace the hinge of the Toshiba Satellite P855-S5312 . Reasons for replacement would be if the screen will not stay in place being to flimsy because hinge. Tools required for guide are phillips size 0 screwdriver.
Wat je nodig hebt
Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
Pry up the panel to gain access to hidden screws.
Turn laptop upside down with the spine facing towards you and locate the microchip.
Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
Remove the three screws on the sides of the screen using the Philips #0 screwdriver.
Once unscrewed, pull the frame off along with the hinge.
