Ga door naar hoofdinhoud
Toshiba Satellite P855-S5312 Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite P855-S5312 Disk Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn laptop upside down with the spine facing towards you and locate the two tabs on the top of the back panel.
    • Move the sliders to the left and right to release the tabs holding the battery in.
    • While the tabs are pushed outwards, remove the battery from the device.
  2. Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: stap 2, afbeelding 1 van 2 Toshiba Satellite P855-S5312 Disk Drive Replacement, Disk Drive: stap 2, afbeelding 2 van 2
    • Once laptop is turned over with the spine facing you, locate the large L shape panel.
    • Using a Philips #0 screwdriver unscrew the 1.5mm screw towards the bottom of the laptop.
  3. Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 3, afbeelding 2 van 2
    • Open the motherboard access cover.
  4. Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a Philips #0 screwdriver, unscrew the 1.5mm screw located near the left edge of the opening near the mother board.
  5. Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the entire disk drive assembly out.
  6. Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite P855-S5312 Disk Drive Replacement: stap 6, afbeelding 3 van 3
    • Flip your device over and rotate the side of the optical drive over to you.
    • Unclip the clips on the side of the automatic release.
    • Use a paper clip or small needle tool to insert in the manual release located on the right of the automatic release button.
    • Once released slide the aluminum case out.
Conclusie
Bishop Clark
225 Reputatie
2 handleidingen geschreven
USF Tampa, Team S10-G2, Thompson Fall 2017 Lid van USF Tampa, Team S10-G2, Thompson Fall 2017
USFT-THOMPSON-F17S10G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 465
