Inleiding
Through this guide you will learn to replace the fan inside of your laptop. Make sure you have the proper tools in order to complete the repair. This kind of repair is usually done to fix the problem of your laptop overheating.
Wat je nodig hebt
Using a Phillips #1 screwdriver, remove the screw from the back cover.
Remove the back cover from the device.
Using a Phillips #1 screwdriver, unscrew the 6 remaining screws attached to the fan.
Unplug the connector connecting the fan to the motherboard.
Remove the fan from the device.
