Inleiding
Use this guide to remove the Toshiba Satellite P55t-A5116 Fan CPU cooler.
Wat je nodig hebt
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Use the #PH0 screw head, remove 4 (5.7mm) screws.
Unplug the battery's 10 pin connector and gently lift the battery out of the laptop.
Using a PH0 screwdriver, remove 2 (5.7mm) screws.
Using a PH0 screwdriver, remove 4 (3.68mm) screws.
3 andere personen hebben deze handleiding voltooid.
