Ga door naar hoofdinhoud
Toshiba Satellite P55W-C5316 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: stap 1, afbeelding 1 van 2 Toshiba Satellite P55W-C5316 RAM Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • To prevent injury, ensure the laptop is powered off before starting your work.
    • Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
  2. Toshiba Satellite P55W-C5316 RAM Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite P55W-C5316 RAM Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite P55W-C5316 RAM Replacement: stap 2, afbeelding 3 van 3
    • Be careful to not crack the panel where the USB and power cord ports are.
    • Insert the opening tool in between the back panel and the laptop to pry it open.
    • The back panel is magnetically attached at the front of the laptop so you may have to move the opening tool along the length of the panel.
    • Lift the panel from the front off of the laptop.
  3. Toshiba Satellite P55W-C5316 RAM Replacement, Battery: stap 3, afbeelding 1 van 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: stap 3, afbeelding 2 van 3 Toshiba Satellite P55W-C5316 RAM Replacement, Battery: stap 3, afbeelding 3 van 3
    • The battery is located in the bottom right corner of the laptop.
    • Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
  4. Toshiba Satellite P55W-C5316 RAM Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite P55W-C5316 RAM Replacement: stap 4, afbeelding 2 van 2
    • Do not tug on the cord or battery. Instead, pull evenly on the connector.
    • Lift the battery and gently pull out the bundled cable connector.
  5. Toshiba Satellite P55W-C5316 RAM Replacement, RAM: stap 5, afbeelding 1 van 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: stap 5, afbeelding 2 van 3 Toshiba Satellite P55W-C5316 RAM Replacement, RAM: stap 5, afbeelding 3 van 3
    • Lift up the flap to expose the RAM chip.
    • Un-clip the RAM by pulling the metal clips away from the chip on both sides.
    • Lift the RAM up from the laptop and pull it away from the connector.
Conclusie
Alec Bonnell
497 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G2, Bailey Fall 2017 Lid van UMass Dartmouth, Team S3-G2, Bailey Fall 2017
UMASSD-BAILEY-F17S3G2
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 636
