Inleiding
The motherboard acts as the central hub of communication between all of the components in your device. A failing motherboard may affect the rest of the components in your device. Symptoms of a failing motherboard include the blue screen of death (BSoD), frozen screen, etc. If you’re looking to replace the motherboard in your laptop, follow these instructions to remove the motherboard from your device.
Wat je nodig hebt
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
