Ga door naar hoofdinhoud
Toshiba Satellite P55W-C5200X Fan Replacement
Wat je nodig hebt
  1. Toshiba Satellite P55W-C5200X Fan Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Fan Replacement: stap 2, afbeelding 1 van 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Fan Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Fan Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Fan Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Fan Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Fan Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Fan Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Fan Replacement, Fan: stap 6, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: stap 6, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: stap 6, afbeelding 3 van 3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  7. Toshiba Satellite P55W-C5200X Fan Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Fan Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  8. Toshiba Satellite P55W-C5200X Fan Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Fan Replacement: stap 8, afbeelding 2 van 2
    • Gently remove the fan from your device.
Conclusie
Marley Pusey
147 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 482
