Ga door naar hoofdinhoud
Toshiba Satellite P55W-C5200X Display Replacement
Wat je nodig hebt
  1. Toshiba Satellite P55W-C5200X Display Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Display Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Display Replacement: stap 2, afbeelding 1 van 1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Display Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Display Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Display Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Display Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Display Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Display Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Display Replacement, Display: stap 6, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: stap 6, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Display Replacement, Display: stap 6, afbeelding 3 van 3
    • Use the Phillips #00 screwdriver to remove the six 5.0 mm screws that are holding the metal brackets on both sides in place.
    • Gently remove both metal brackets.
  7. Toshiba Satellite P55W-C5200X Display Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 7, afbeelding 3 van 3
    • Remove he three wires connected to the motherboard.
  8. Toshiba Satellite P55W-C5200X Display Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 8, afbeelding 3 van 3
    • On the other side remove the four remaining wires from their ports.
  9. Toshiba Satellite P55W-C5200X Display Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite P55W-C5200X Display Replacement: stap 9, afbeelding 3 van 3
    • Lift two sets of metal brackets up, one in each corner.
    • Depending on the force needed on your specific device, you may need to use the spudger.
  10. Toshiba Satellite P55W-C5200X Display Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite P55W-C5200X Display Replacement: stap 10, afbeelding 2 van 2
    • Gently lift the device away from the display assembly.
    • Be aware of the wires attached to the screen so they don't snag on anything.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hadi Termos
238 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 Lid van UMass Dartmouth, Team S1-G2, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G2
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 34
Altijd: 872
