Ga door naar hoofdinhoud
Toshiba Satellite P50W-C Wifi Module Replacement
Wat je nodig hebt
  1. Toshiba Satellite P50W-C Wifi Module  Replacement, Back Cover: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Turn the laptop off, unplug the AC adapter, and any other auxiliary components.
    • Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
  2. Toshiba Satellite P50W-C Wifi Module  Replacement: stap 2, afbeelding 1 van 1
    • Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
  3. Toshiba Satellite P50W-C Wifi Module  Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P50W-C Wifi Module  Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to pry under the back cover until it pops off.
  4. Toshiba Satellite P50W-C Wifi Module  Replacement, Wifi Module: stap 4, afbeelding 1 van 1
    • Locate the Wi-Fi module in the device which is located next to the ram.
  5. Toshiba Satellite P50W-C Wifi Module  Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the 3mm JIS head screw with J1#1. This screw is holding the Wi-Fi module to the device
  6. Toshiba Satellite P50W-C Wifi Module  Replacement: stap 6, afbeelding 1 van 1
    • Remove the black and white wires that are connected to the device by gently pulling on it.
Conclusie
Sarah Fordjour
450 Reputatie
4 handleidingen geschreven
USF Tampa, Team S3-G2, Cannon Fall 2017 Lid van USF Tampa, Team S3-G2, Cannon Fall 2017
USFT-CANNON-F17S3G2
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 584
