Ga door naar hoofdinhoud
Toshiba Satellite P205D-S8804 Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite P205D-S8804 Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • With the screen on a flat surface, remove the screws in each corner of the screen. There will be 4 in total.
    • Note: The screws for the screen may be hidden under rubber pad at the top of the screen so they will have to be removed.
  2. Toshiba Satellite P205D-S8804 Screen Replacement: stap 2, afbeelding 1 van 1
    • Using a metal spudger wedge open the front and back cover of the screen.
    • Take care to not damage the camera in the process.
  3. Toshiba Satellite P205D-S8804 Screen Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P205D-S8804 Screen Replacement: stap 3, afbeelding 2 van 2
    • After the front cover is removed remove the two screws at the very bottom of the screen.
    • This will give you access to the screws running along the side of the screen.
  4. Toshiba Satellite P205D-S8804 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the four screws on the each side of the screen. There will be eight in total.
    • We recommend starting from the bottom and working upward.
  5. Toshiba Satellite P205D-S8804 Screen Replacement: stap 5, afbeelding 1 van 1
    • Lay the screen flat on the keyboard so they the back panel can be accessed.
    • Remove all the tape on the video cable that connects the screen to the computer.
  6. Toshiba Satellite P205D-S8804 Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the video cable from the screen.
    • After the video cable is removed the screen is free and can be removed from the computer.
Conclusie
Caroline Camp
1 Reputatie
3 handleidingen geschreven
Baylor, Team 3-2, Whitney Spring 2017 Lid van Baylor, Team 3-2, Whitney Spring 2017
BU-WHITNEY-S17S3G2
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 86
