Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
This guide will take you through the steps to remove the RAM from the laptop for replacement. You can use this guide to replace malfunctioning RAM chips or to replace your older RAM chips with newer or better chips.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the laptop over so the bottom is facing upward and the battery is on top. Slide the tab below the battery to the left.
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Slide and hold the tab on the right side of the battery to the right. While holding the right tab, slide the battery upward and out its socket.
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  5. Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  6. Lift and remove the RAM slot cover. Lift and remove the RAM slot cover.
    • Lift and remove the RAM slot cover.
  7. To remove the first RAM chip, gently press outward on the tabs on both sides of the chip The RAM chip should pop up after releasing the tabs.
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  8. Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  9. To remove the second RAM chip, repeat the previous steps To remove the second RAM chip, repeat the previous steps
    • To remove the second RAM chip, repeat the previous steps
Conclusie
Davin
250 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-8, Amido Winter 2014 Lid van Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 300
