Ga door naar hoofdinhoud
Toshiba Satellite P205-S8811 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite P205-S8811 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite P205-S8811 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Toshiba Satellite P205-S8811 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Place the head of a plastic opening tool underneath the plastic strip lining the top of the keyboard, right above the "PGUP" button.
    • Next, pull the strip up using a plastic opening tool with a light force, until it pops off.
  4. Toshiba Satellite P205-S8811 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Lightly lift from the side that was popped up earlier in order to pop the rest of the strip off of the laptop.
  5. Toshiba Satellite P205-S8811 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite P205-S8811 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Use a #1 Phillips screwdriver to take out the four 4mm Phillips #1 screws that were underneath the plastic strip.
  6. Toshiba Satellite P205-S8811 Keyboard Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite P205-S8811 Keyboard Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite P205-S8811 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Be careful to not lift up on the keyboard too quickly or harshly; there is a ribbon cable connecting the keyboard and the base which may be breakable.
    • Lightly lift up on the keyboard from one of its top corners and pull it towards the screen so you can safely remove the ribbon cable.
    • At the base of the ribbon cable, there is a tiny tab that runs across the width of the connector. Flip it up. You can now pull the ribbon cable free with no resistance towards the monitor.
    • With the cable unplugged, the keyboard can be lifted away from the laptop.
Conclusie
Andrew Meyer
245 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-8, Amido Winter 2014 Lid van Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 764
