Ga door naar hoofdinhoud
Toshiba Satellite P105-S6147 Screen Replacement
  1. Toshiba Satellite P105-S6147 Screen Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Screen Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Screen Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite P105-S6147 Screen Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Screen Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 4, afbeelding 3 van 3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Screen Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite P105-S6147 Screen Replacement: stap 5, afbeelding 2 van 2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
  6. Toshiba Satellite P105-S6147 Screen Replacement, Screen: stap 6, afbeelding 1 van 2 Toshiba Satellite P105-S6147 Screen Replacement, Screen: stap 6, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to unscrew the four 3 mm screws connecting the screen to the keyboard.
  7. Toshiba Satellite P105-S6147 Screen Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the white cord that is connected from the screen to the keyboard.
    • Disconnect the cord from the bottom of the keyboard.
    • Gently pull the cord out from the fastening clips on the keyboard.
  8. Toshiba Satellite P105-S6147 Screen Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite P105-S6147 Screen Replacement: stap 8, afbeelding 2 van 2
    • Remove the rubber pads from the four corners of the screen, revealing four screws.
  9. Toshiba Satellite P105-S6147 Screen Replacement: stap 9, afbeelding 1 van 1
    • Remove the plastic bevel from around the screen.
    • Pull the bevel up and off.
  10. Toshiba Satellite P105-S6147 Screen Replacement: stap 10, afbeelding 1 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 10, afbeelding 2 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 10, afbeelding 3 van 3
    • Use the Phillips #0 screwdriver to remove the 4 mm screws located on the top of the screen and the sides.
  11. Toshiba Satellite P105-S6147 Screen Replacement: stap 11, afbeelding 1 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 11, afbeelding 2 van 3 Toshiba Satellite P105-S6147 Screen Replacement: stap 11, afbeelding 3 van 3
    • Remove the 2 white plugins from the bottom of the screen.
    • Pull gently on the white plugs to remove them.
  12. Toshiba Satellite P105-S6147 Screen Replacement: stap 12, afbeelding 1 van 1
    • Pull the screen out of the laptop cover.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 309
