Ga door naar hoofdinhoud
Toshiba Satellite M55-S135 Optical Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite M55-S135 Optical Drive Replacement, RAM: stap 1, afbeelding 1 van 1
    • Orient the laptop so that it is closed, faced down and has the battery facing away from you.
    • Use the Phillips 00 screwdriver to remove the 7.50mm screw from the panel.
  2. Toshiba Satellite M55-S135 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the cover to reveal the RAM compartment.
  3. Toshiba Satellite M55-S135 Optical Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite M55-S135 Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Rotate the laptop 90 degrees clockwise.
    • Pull back the two silver clips that hold the RAM in place.
    • Gently pull the RAM out of the slot and lift up to remove the RAM from the laptop.
  4. Toshiba Satellite M55-S135 Optical Drive Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the 6.50mm screw holding the gray metal bracket in place.
  5. Toshiba Satellite M55-S135 Optical Drive Replacement: stap 5, afbeelding 1 van 1
    • Turn the laptop 180 degrees then tilt the near side up.
    • Push the back side of the optical drive out of the laptop using the plastic opening tool.
  6. Toshiba Satellite M55-S135 Optical Drive Replacement: stap 6, afbeelding 1 van 1
    • Pull the optical drive out of the laptop using your fingers.
  7. Toshiba Satellite M55-S135 Optical Drive Replacement: stap 7, afbeelding 1 van 1
    • Using the Phillips 00 screwdriver, unscrew the two 2.50mm screws that connect the metal bracket to the optical drive.
    • Remove the bracket from optical drive.
Conclusie
Yuheng Huang
13 Reputatie
1 Handleiding geschreven
Cal Poly, Team 7-11, Maness Winter 2013 Lid van Cal Poly, Team 7-11, Maness Winter 2013
CPSU-MANESS-W13S7G11
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 620
