Ga door naar hoofdinhoud
Toshiba Satellite M55-S135 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite M55-S135 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Toshiba Satellite M55-S135 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite M55-S135 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. Toshiba Satellite M55-S135 Keyboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite M55-S135 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  4. Toshiba Satellite M55-S135 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  5. Toshiba Satellite M55-S135 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
Conclusie
klismann Evora
109 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-7, Cichon Spring 2014 Lid van UMass Dartmouth, Team 5-7, Cichon Spring 2014
UMASSD-CICHON-S14S5G7
4 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 690
