Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Learn to replace your wifi card.
Wat je nodig hebt
Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Één andere persoon heeft deze handleiding voltooid.
